New Gears are whining
#21
RE: New Gears are whining
gear whine normal and will go away after about 500 miles.
what a load of B.S. the gears are hardened steel. if they whine from the get go, they will whine until a new pattern is worn....or better yet, they break your rear-end. either way, your axle is an accident waiting to happen. If you leave it whining, you may have to replace your axle shafts as well.
make the shop fix it, and do it properly...for free of charge
#23
ORIGINAL: Dan04COBRA
Maybe he was saying you should wait for them to break in your rear-end.
They shouldn't whine. He needs to adjust them.
You should hear nothing.
#25
ORIGINAL: dr0pt0pGT
Is it true that some manufacturers just make noisy gears? Or it shouldnt matter?
So the conclusion is...
New Gears + Whining at decel = Bad install, need to be checked.
Thanks everyone.
Thanks everyone.
#26
from what ive read the motives are harder to install than the frpp gears.
my buddy has richmond gears that whine in his ls1 z28, i asked him if the install was wrong or something. he said richmond gears always whine. same installer did frpp 3.73's on yelw02gt and they do not whine.
#29
ORIGINAL: SINISTER
I installed my own and had no problems at all. Since you already paid to have them installed, take them back and tell him to fix it. Tell him to make sure the backlash is correct (between .008 and .012) and that the pinion depth is good.
#30
FRPP gears here and they never whined and I broke mine in in one day def bad install I asked the guy at the performance shop while he was doing mine a while back and they def are not supposed to whine.
