4.6 G.T motor converted To Cobra motor
RE: 4.6 G.T motor converted To Cobra motor
while i think youd be better off either forging and boosting your 2V....
i gotta admit...nothing on this earth sounds like a 4V with longtubes, an O/R Prochamber and Mac Catback, screaming at 6000+ RPMs
just buy a complete motor and trans from a 03-04 cobra alot cheaper and easier and you dont need to build a bottom end or anything like that cause they can take up to 1000RWHP....
thats if he can find one for a decent price
ORIGINAL: BADSEED
ORIGINAL: 97targa
Sure you can! The compression ratio may not be the same, but you can slap on 4v heads onto a 2v block! You would need the front timing cover, complete upper/lower intake and accessories, wiring,and headers to go with it. I would reccomend buying a used complete drop in motor.
Why would you want to "build" the motor just because it's out of the car????? That's ridiculous and very costly. As long as the motor runs good and you don't plan on running over 8lbs of boost, don't waste your time! It's very expensive to rebuild and you must know what you are doing to properly degree the cams on a 4v motor.
ORIGINAL: SmallFeesh
You can't "change" your motor into an actuall Cobra motor... (if you are going to buy a motor you might as well build it since it will be out of the car anyways)
Your complete post makes you sound IDIOTIC!
ORIGINAL: 97targa
What do you think a short post thats just calling someone an Idiot makes you? If you think he's an Idiot please at least take the time and tell him why!
and before you say you didn't call him an idiot, it's called IMPACT vs INTENT. As most would read it, it's an implied insult.
