O2 SENSOR CODE P0156
Old 10-10-2007, 01:48 PM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
Default O2 SENSOR CODE P0156
CEL is still on after MIL eliminators and i even tried the homemade eliminators after that.It saysthat it is the#2 position in bank 2. From what i understand is that this is the one that measures the air/fuel ratio. Is that throwing off everything if that code stays on? Does anybody else have any more info on this code?
Ive been dealing with this for about a year now. Its getting old.
1fstblckgt is offline
Old 10-10-2007, 02:16 PM
uberstang1
Chupacabra
uberstang1's Avatar
Default RE: O2 SENSOR CODE P0156
Position 2 bank 2 is a rear oxygen sensor, all it does is make sure the cat is working properly. The rear oxygen sensors have no affect on the air fuel and how the car will respond and run, its strickley to check if the cat is working, most people have the rear o2 sensors turned off with a handheld, so dont worry it wont affect how you car runs.
uberstang1 is offline
Old 10-10-2007, 02:18 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: uberstang1
Position 2 band 2 is a rear oxygen sensor, all it does is make sure the cat is working properly.
+1
Bank 2 is the side of the car the #1 cylinder is NOT on. Sensor 2 is rear.
The A/F ratiois controlled by the front two which is why you never want to put MIL's on the front 02 sensors.
Derf00 is offline
Old 10-10-2007, 02:19 PM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
Will somebody please meet me in bham with a handheld and turn this SOB off then....?
Old 10-10-2007, 04:07 PM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
Anybody got any other ideas how to get rid of it without a handheld?
Old 10-10-2007, 04:29 PM
ackuric
ackuric's Avatar
obviously something is wrong in the wiring of your homemade mil on the driver side rear o2. take it off and inspect your wiring.
ackuric is offline
Old 10-12-2007, 07:49 AM
uberstang1
Chupacabra
uberstang1's Avatar
Some times MILs simply dont work, try unplugging ur battery for a few minutes to reset the PCM, and maybe it wont come back on
Old 10-12-2007, 10:09 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
MIL eliminators (as opposed to O2 semsorsimulators) just condition the otherwise normal signal from the rear O2 sensors so as to trick the PCM into thinking the catalytic converters are in place and working--I.e. they require that the rear sensors be present and working. [/align][/align]If the sensor is bad then there is no "normal" signal to condition and the PCM sees a bad rear sensor...[/align][/align]Read more about how MIL eliminators work here...[/align] [/align][/align]Could also be bad wiring of course...[/align]
cliffyk is offline
BOB ROME
07-26-2023 01:54 PM
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: O2 SENSOR CODE P0156
