Best heads for the $$$
Christmas is coming up and me and my brothers have decided to get my dad a H/C/I combo. Since I am the oldest I automatically got the heads as my gift to him so I was wondering. What is the best heads for the money if I want the car to be putting about 300hp to the wheels? I know that the heads and cams and intake all work together but for just the heads what would be the best set to get about that power to the wheels with a good matching set of cams and an intake. He uses this car as a daily driver so a crazy set like the AFRs 205 are out of the question, he wants to keep this thing streetable.
RE: Best heads for the $$$
Patriot Stage 2 heads are nice and say, Stage 2 N/A Comp Cams will do the trick to 300-/+ hp. Also you should throw in some beehive valve springs too. For Stage 1 cams you dont really need em, but for Stage 2 I'd definitely install the beehive valve springs.
Edit: This is assuming your dad has a 99-04 GT. I just took a wild guess that he has a 99-04 GT. If he doesnt, then oh well haha.
I have read somewhere, I think VT's website, that with Compcams Stage II camshafts, you need notched pistons for valve clearance. So if that is at true, stay away from those, otherwise your building a motor....
I could be wrong but I do not think that is the case. I'm pretty sure I met a guy with Stage 2's with regular pistons at the track but I'm not really sure I cant remember exactly what he had. Oh and he had aftermarket heads.
ORIGINAL: wes ley n the G T
ORIGINAL: GhostRider02GT
Comp Cams Stage 2 Billet camshafts 99-04
Our Favorite, awesome sounding idle, great power increase, raised redline, computer tuning recommmended for peak performance but not required. 3.55+ gears recommended, Valve springs required, must use notched pistons for valve clearance.
That is cut straight from www.modularmustangracing.com. Now about the retarding the timing, IDK, someone else can chime in on that and maybe they could work. But why have the guess work, just get VT stage II's, a lot of people have those cams and heads and I have heard pretty good things about em.
Okay well it seems that 300whp is going to require some work that I can't do by myself, so how about 300 crank hp. I am really just looking to get him a H/C/I combo that I can bolt on for him and give a good increase in power.
