tko speedo plug size?
what size plug do i use for the speedo hole? i am getting the tko in the mail tomarrow and i am going to install it. sweet!
does the tko come with the 4 monting bolts?
RE: tko speedo plug size?
what 4 mounting bolts? you use all your stock bolts for it. you have to flip the crossmember around backwards. also dont forget your stock clutch wont fit. the tko500 takes a 26 spline clutch when the stock i believe is 10. not sure on the plug size but you will find out when you recieve it. it takes a different speedo sensor i believe too.
i have a quicktime sfi bellhousing. the bellhosing has threads for the 4 tranny bolts. i guess i'll find some, its cool. the 500 is 26 spline and i do allready have a 26 spline clutch.
you believe it takes a different speed sensor? do you believe or know? lol your sig says you have a tko
the tko i got had the sensors allready on it. 2 speed sensors and a reverse pigtail. i have no idea what to plug that hole with i mentioned befroe. would it even be at murrays or autozone?
11-10-2015 11:39 AM
musnicki
09-23-2015 07:11 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
