What does this mean?
When i start my car in the morning - it has a rough idle, like a cam. And has a hissing sound from what appears to be the intake area. But after a minute or so it goes away and the idle is bak to normal. Any ideas?
RE: What does this mean?
Just a thought, probably wrong, but have you checked your air and fuel filter to make sure they are clean? I'm not too sure what would cause a rough start that solves itself in a minute or so.
ORIGINAL: grey goose
That sounds complicated......is that an easy fix and or expensive?
I have an IAC restrictor in mine, when cold, I do hear a hissing from the engine bay, however my idle is just fine. The sound is just the larger-than-normal volume of air going through the IAC.
A vacuum leak would explain it running as if it were cammed though... Check your air intake, be sure it's all tight... Something is probably loose there.
fuel filter would be a good idea if it has not been serviced recently, but if its clogged, it will not fix itself, it will just chug and chug, sounds like you have some kind of air leak.
