Are these good-Caster Camber Plates?
I need some camber plates, and was wondering if any one had these, or know about the quality of these. They are the UPR Shark Steel Caster Camber Plates. Any advice or help you have will be greatly appreciated. Thanks
http://cgi.ebay.com/ebaymotors/UPR-S...spagenameZWDVW
RE: Are these good-Caster Camber Plates?
Same here.Get MM's or Steeda.
I have set of MM parts and the adjustments they alow did make a noticeable difference.
There have been problems in the past with the top bearing being loose in the top plate but MM seems to have fixed the problem.
There was a rattling noise when you would go over even the smallest bumps in the road due to the bearing working istelf loose.
Spend the extra money and get the MM's
