Car won't start...
Old 10-16-2007, 06:52 PM
Mark99GT
Mark99GT's Avatar
Default Car won't start...
My battery (old) was bad, so I had to jump my car evertime I wanted to start it. It always started up fine, no problems. Today I finally got around to getting a new battery, swapped it in, and now the car won't start. I get one click and thats it. Ihad them dispose of my old battery, so I cant throw it back in to test.
How do you test a battery to see if its good? Its a brand new die hard gold from sears. Is there anything stupid Im forgetting here? Couldn't be PATS related could it? Im thinking the starter is bad, but it worked fine 2 days ago.
Kinda weird that after a battery swap it all of a sudden wouldn't work now. The connections are tight, I can't think of any ground wires or anything that would be loose. Any ideas?
Mark99GT is offline
Old 10-17-2007, 08:49 AM
1fstblckgt
I ♥ Acer
1fstblckgt's Avatar
Default RE: Car won't start...
Are your connections good on the terminals to the battery?? Make sure they are really tight and you cant move them at all.
1fstblckgt is offline
Old 10-17-2007, 08:54 AM
vermontstang
vermontstang's Avatar
Did you sand down the terminals a little before connecting? Just roughin them up a lil. Also did you clean the connections too? I always do these 2 items when putting in a new battery. Probably useless but worth a try!
vermontstang is offline
Old 10-17-2007, 08:55 AM
03mustgt
03mustgt's Avatar
If you can jump it and get it too start it isnt the starter. Turn your headlights on and see if they are really dim.
03mustgt is offline
Old 10-17-2007, 09:09 AM
Mark99GT
Mark99GT's Avatar
No, I can't jump it with the new battery (forgot to mention that). Headlights, vents and stereo system all work fine, even when they're all on at the same time. So its definitely getting power. The terminal connections are tight, but I didn't sand or clean them. They looked fine when I took the protective caps off of them. I don't know, its gotta be a bad connection somewhere. I just put lts on too, getting at the starter (if I have to) is gonna be a bitch.
Mark99GT is offline
Old 10-17-2007, 10:21 AM
trickdriller
trickdriller's Avatar
LOL, sorry man, but it does sound like the starter's your problem. You said you get one click and that's it? Maybe the gears are stuck and it can't slide into place? I don't know, just trying to save you from having to swap that thing out. You could always try beating it with a rubber mallet or something
trickdriller is offline
Old 10-18-2007, 07:51 AM
vermontstang
The terminals will look clean, but you should roughen them up before installing.
ohfarrell
10-18-2015 11:27 PM
chain
08-17-2015 08:52 AM
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car won't start...
