running lean. need help badly
Old 10-17-2007, 10:48 AM
ShinobiOfLegends
ShinobiOfLegends's Avatar
Default running lean. need help badly
ok so icheck my PCM for codes on a weekly basis for good measure and pulledthe codes 1131 and 1151. i first thought theMAF and 02 sensorswere bad so i replaced the 02 sensors and took it to Ford for the MAF and they said it was fine and in fact has been replaced before. i asked them what else it could be and and them since it was detecting problems on bank 1 and bank 2 it was something that would affect both (obviously....i already figured that out) and for $68 they would keep it for 2 days and figure it out. obviously i'm not doing that... i'm not having any problems though. no hesitation, no increase in MPG (i been getting 16), no weird sounds. any ideas before i do have problems?
ShinobiOfLegends is offline
Old 10-17-2007, 11:39 AM
ZW99GT
ZW99GT's Avatar
Default RE: running lean. need help badly
You could have a vaccum leak. There is unmetered air coming in from somewhere. I had a n20 backfire, and it popped my Intake pipe off the maf. It gave those SAME CODES YOU GOT! 1151 and 1131, for lean conditions.
Check for leaks any and everywhere.
ZW99GT is offline
Old 10-17-2007, 11:58 AM
ShinobiOfLegends
i've checked twice already. and i've done the problem tricl, no change in rpms or anything.
Old 10-17-2007, 12:37 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
injectors or faulty fuel pump?
2002GTAUTOVERT is offline
Old 10-17-2007, 12:42 PM
ShinobiOfLegends
i had the injectorsand fuel lines cleaned in october when the fuel filter was replaced. i dunno about the fuelpump. how do i check??
Old 10-18-2007, 11:55 PM
ShinobiOfLegends
bump
2007StangV6
01-28-2016 06:09 PM
Mobiusone stang
09-07-2015 08:46 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: running lean. need help badly
