New clutch help
New clutch help
Ok, so I'm ordering a new clutch from summit. They have the 2 Ford racing clutches.....which is better? The specs are the same, but the King Cobra costs 40 bucks more[&:]
Brand: Ford Racing Performance Parts
Product Line: Ford Racing Clutch Kits
Input Spline Quantity: 10
Input Shaft Diameter (in): 1 1/16
Disc Diameter (in): 10.500
Disc Material: Organic
Disc Style: Sprung hub
Pressure Plate Style: Diaphragm
Throwout Bearing Included: Yes
Throwout Bearing Style: Standard
Alignment Tool Included: Yes
Pilot Bushing Included: No
Flywheel Included: No
Counterweight Assist: No
Mounting Hardware Included: No
Quantity: Sold as a kit.
Performance parts for your Ford.
Clutch Set, Ford Racing, Heavy Duty, Organic Disc, Diaphragm Style Presure Plate, Kit
Ford Racing clutch kits are set up to give you more capacity. They can handle 40 to 50 percent (or more) greater torque than the stock units. Their pressure plates are made from nodular iron, their clutch discs have a sprung hub for shock absorption and smooth operation, and they are made slightly thinner for quicker release.
Back to Search Results
Alignment Tool Included: No
Notes: This is the King Cobra kit.
Clutch Kit, King Cobra, Ford, Mustang, 1.0625 in x 10 Spline Hub, Disc, Pressure Plate, Throwout Bearing, Kit
RE: New clutch help
im pretty sure that its designed for higher HP uses, its more a performance clutch. I know that it can hold more ft/lbs than the stock-and you are right its only 40bucks more so just buy the damn thing and when you drive your car you WILL feel the diff
RE: New clutch help
hows that possible MD?? never hear of 500HP stangs with stock clutches... is that the original stock clutch? IF SO... WEIRD i never knew they can take that kinda abuse with that much HP
RE: New clutch help
ORIGINAL: jdaniel
I wouldnt go with a ford racing clutch. Thats what I have now and after 20,000 miles it got really weak. I think it needs replacing.
RE: New clutch help
Devin. I would recommend King Cobra, i have it i installed it. Its easy, its nice, it grabs. Also i got mine from Mustangtuning.com free shipping!! Awesome deals too. Make sure you buy a clutch alignment tool and have youre flywheel resurfaced. Other than that, have fun and especially with the starter bolts. lol
