Check Fuel Cap Light On!!!
Hey guys, my 01 GT had some problems last week i started it up and noticed fuel started pouring out of the bottom of her, and when I popped the hood I noticed the O ring on one of my injectors was bad so i change the O ring and pushed the injector back in and drove around no fuel no where to be found after I did this but I did smell gas, i was thinking it was just where it had already sprayed on the manifold, and i kept smelling it for about 2 days. and last night my Check Fuel cap light has illuminated! Can anyone help me! I need help bad![:'(]
RE: Check Fuel Cap Light On!!!
Did you check the fuel cap?
Alright seriously....easy things to check, other injectors, fuel filler neck, fuel filter, pull codes. I would probably pull codes first and foremost. Though the cap light came on, maybe it is for soemthing related and not exactly the cap. Check everything easy first.
ORIGINAL: joeybutts
I had the grommet between the filler neck and fuel tank start leaking and it never had a MIL.So it could be the filler neck is loose.You'll be able to see the gas leak from under the car.
ORIGINAL: Chopper
Very rarely my check fuel cap will come on for a day then go away, I never did figure out what was cuasing it. Usually it would happen after i fill the tank, then later that same day the light would come on and I would go check the cap and the fuel door, but the light would stay on, the following day the light would be gone. this has not happened in a long time now but its baffling when it does.
