diablosport predator
has ne1 used a predator on a 02 stang in her yet??? i m purchasing 1 and would like to know if there was a noticable difference... i have a CAI,cat back exhaust, 75mmtb and plenum... what do u think the outcome would be??? PLEASE HELP
RE: diablosport predator
I've been using a Diablo Predator tune in my 03 Mach for the past year. I think you'll like the performance boost it can provide, I certainly do. I have similar performance mods to yours: a C&L intake w/ 85mm MAF housing, MRT catted H-pipe, SLP catback, and 4.10 gears.
i have a 2000 GT and the tuner i use is the same model number you would need... and yes there is a noticeable difference... install the tune then modify that tune... raise the timing 2 more in the 4000-7000 range... actually i did both, but you only need 4000-7000 rpms when racing
I have one on my 03 GT, it's auto and it helped with crisper shifts. You can also use it to adjust for gears, etc. I don't know how it would work on a 5spd. I'd only get it if you're getting gears or want to use it w/a dyno.
