Rear End Set up
Rear End Set up
Correct me if this is wrong. Is the pinion shim number on the head of pinion gears the thickness of the head plus the thickness of the bearing plus the apporpiate thickness of shims?
RE: Rear End Set up
There is one sure way to find out, get a dial caliper and measure it.
Are you doing your own gears? If so, just use the MHD method to calculate the pinion depth. I did this and my gears turned out great.
RE: Rear End Set up
I don't really see why it shouldn't. A measurement is a measurment, and the gears are pretty much all the same, right? My Ford Racing gears were the ones manufactured by Motive, and mine turned out great. What gears are you using?
RE: Rear End Set up
The pinion head is marked with PINION depth...measurment...thats the distance measured at the top of the pinion to the carrier bearing center line....
that measurement marked it WHAT is needs to be..with the pinion shim,bearings, added...The MHD method seems to be a very, easy,acurate method...Although, I actually have the correct tools needed to do it porperly without it..and have done so forever.....
answer to your question.....YES...
RE: Rear End Set up
ORIGINAL: SINISTER
RE: Rear End Set up
ORIGINAL: 4.698GT
Ok, does the MHD method work with non ford gears. If so, I'm golden
RE: Rear End Set up
ORIGINAL: 8banger
Should as long as no ones ever had it apart,and has the stock gears,with the original pinion shim...
ORIGINAL: 4.698GT
Looks like you are golden 4.698GT.
musnicki
09-23-2015 07:11 AM
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
