4R70W from a V6
4R70W from a V6
Has anyone put a 4R70W automatic from a V6 mustang into a V8? My trans just went out in my 2000 GT. I know thereare some slight changes to the internals and the torque converter will probably have a higher stall. Will it bolt right in and will the wiring harness be the same? Any help would be appreciated. Thanks
RE: 4R70W from a V6
yea their could be some issues with the wiring harness. I'm not sure of the bolt pattern though, I doubt it is the same because the V6 uses the T-5 5speed with the same housing from the 5.0 I think and that is different for the 4.6....I will find out tomorrow though in class. I'll look it up on alldata.
RE: 4R70W from a V6
I don't think that the bell housings are the same. I believe that the bell housing for the V6 4R70W has a similar design and bolt pattern to the old 5.0s. Since the 4R70W for all models don't have a removable bell housing youprobably couldn't use the tranny from the V6. Maybe you could swap the internals.
