missfire again
missfire again
so i've got another missfire problem.
this time no code.....yet. but i can feel the miss pretty seriously when i try to accelerate and a little when i bog down
any likely problems?
RE: missfire again
I use to have that misfire problem, but a guy told me to take a pair of needle nose pliers and just bend the little tabs on the cop's just a little bit.And it will contact the plug ina little better.So I did that on all my cop's and have not had a problem sense.
RE: missfire again
ive had this problem twice now. i replaced my intake manifold and it was misfiring bad when i accelerated. then after the track a couple weekends ago same thing. not sure what the problem is. i replaced all the plugs and if it comes back im gonna replace the ignition with MSD also. it threw a code once misfiring in cyl 1 so im gonna replace the cop on that cyl this paycheck anyways (or maybe all 8 depending on the price). both times its fixed itself after it sat for a few hours. not sure whats up but sounds like we got the same prob [:@]
RE: missfire again
ORIGINAL: Brute03
what tab? in the connector?
There is two little brass tabs that stick out about 3/8" just twist them a little with some needle nose pliers,and plug the harness back on,and put some die electric grease in there to.
HendersonDavid
09-09-2009 05:32 PM
