Top Speed Problem???
#33
RE: Top Speed Problem???
ORIGINAL: 99BlackPonyGT
to everyone who says you can hit 160 or 190 with 3.73s....you must not actually drive a car that has them....about 135 with my 3.73s im at about 6k rpms .... if i removed the rev limiter and ran it to like 8grand im sure i could maybe hit 155 but not for very long [&:]
If your hitting 6K RPM at 135 you either have a really steep gear in the car or your clutch is slipping like crazy.
To the OP: Clean your MAF.
I dunno what else to tell you. Sounds like somehow you have a speed limiter to me if its accelrating real fast to 120 and then suddenly stops. A limtier is pretty obvious when it hits... it will cause the car to studder and slow, accelrate then slow, over and over.
Why does this matter though??? You say the car runs real good, has plenty of power, WHY are you doing 120+ MPH enough that you care? You definatly don't have the power levels to be racing anyone at that high of speed, and your definatly nowhere near that trap speed at the track. Speed kills man, running it up to 100 every once in awhile is one thing, or even a top speed run or two, but if its bothering you this much you must be doing it all the time.
Chances are your not even running a tire rated to exceed 120 MPH, and even if you are your taking a pretty big chance just going out and pinning the throttle all the time and running it to 120+. This is coming from a guy thats an admitted addict to street racing. Racing is one thing though... just going out nad maxing out the car is another.
In short, it might not want to go past 12x mph... but you don't need to go that fast anyway. It still runs good, so why do you care?
#34
Z-rated tires. Who the hell has anything less? Anyway bout the speed...I don't do it all the time....just didnt know if the tranny was going bad or something in the motor.....you would know this if you looked at my first post.
#35
ORIGINAL: 99StangAnd02R1
Engine is pretty much the same thing, lack of top speed doesn't really point to anything wrong with it, espcially since it runs good otherwise.
Your car is fine, its just gotta be a limiter thing. The only way you can tell for 100 percent surethough is get it on a dyno and see what the WHP and a/f ratio numbers are and then post em up here for results.
BTW, I'm not trying to bust your *****, I just don't want to see another member post with a busted stang and/or dead/hurt member.
#36
#38
Well oh well. Anyway I'm happy...Have a friend with a new STi and we were messing around and I pulled on him....lol. Damn ricers don't know when to quit. $35000 against my $14000 and I still pulled on him from 2nd gear on up.
ShaneB26154
35
03-04-2021 04:05 AM
