Broken clutch peddle cable
RE: Broken clutch peddle cable
LOL. are you kidding me. I could change youre clutch cable in about 5 minutes.
Step by Step process ok....
1. Go under youre dash and look for a white thing attached to youre clutch pedal. Pull up on the clutch pedal and see if you can remove the cable from the white thing ( quadrant) If not.. proceed to step 2.
2. Get undercar and look at there the cable goes into the trans, remove the cover with the 8mm bolt. Then get a bar to pry on the clutch fork. And get the cable out of there. Then remove the 8mm bolt on the fender ( drivers side) and then remove the bolt from the firewall and remove the whole thing...
3. to put back in reverse process.
Did you laugh at me ?? !!!!
haha , its aight , man I dont know much IM learnin though
thanx though man I baught a new clutch cable already yesterday 60 bucks ' its better then my old one its one that I can like change the length of wire thats let loose and move my peddle lower too the ground .. so I guess it was a good thing my old cable broke , IM gonna try out what yous aid tommorow , thanx for the help
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
09-25-2015 06:58 PM
