Clutch adjustment?
Old 10-30-2007, 12:34 PM
Quicktime_GT
Quicktime_GT's Avatar
Default Clutch adjustment?
I recently had my transmission rebuilt and installed a centerforce dual friction clutch. It seems now that the clutch may be "dragging a little," there is sometimes a notch at neutral inbetween gears and sometimes when I go to put it in gear you can kind of feel it dragging or something..
I do not have a quadrant adjuster
Any tips?
Quicktime_GT is offline
Old 10-30-2007, 11:08 PM
bigtom
bigtom's Avatar
Default RE: Clutch adjustment?
if your quadrant is stock then try grabbin your cluch pedal and lift it towards you, there is a rachet mechanism that will take up any slack. i had to do this after installing a new clutch
bigtom is offline
Old 10-30-2007, 11:11 PM
01GT4.6
01GT4.6's Avatar
do as bigtom said or get a firewall adjuster.
01GT4.6 is offline
Old 10-30-2007, 11:13 PM
Quicktime_GT
I've done this several times and it feels the same.. how much does it adjust it each time?
Old 10-31-2007, 12:17 AM
bigtom
bigtom's Avatar
as i remember you only need to do it once. maybe a firewall adj is the solution.
bigtom is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Clutch adjustment?
