Electric water pump.
RE: Electric water pump.
Yes and yes. My tuner said that a Mustang with a Prochargerat 8 psi will normally get around 350 rwhp (Mustang Dyno). Minegot 385. I've read that the BBK 75mm TB/Plenum will give you an additional 18-20 rwhp with a supercharger. The rest I attribute to the electric waterpump which is advertised as adding 11-12 rwhp. Of course different conditions may result in a different outcome, but it appears to work as advertised. I've got around 3500 miles on the set up and have experienced no problems.
P.S. I ended up with the electric water pump because the previous owner had installed underdrive pulleys and I did not have the originals. UDPs do not work with superchargers. Instead of going backwards and buying a stock waterpump pulley, I went with the electric water pump. I did have to buy a stock crank pulley.
My car was at the tuner's when we discovered I needed it so I bought it through them, Exotic Performance Plus. (www.exoticperformanceplus.com).
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
