4.6 (99 to 04) Swap questions
As you all know, I have a 99 gt and my motor seized. I found a new motor with 18 thous. miles on it but its from an 04 gt. will it bolt right up, or will I have troubles since I don't have a T-3650 tranny?
Long time no talk mf'ers.
RE: 4.6 (99 to 04) Swap questions
ORIGINAL: Mark99GT
It'll bolt up no problem. Youll just need a new 6 bolt 10.5" flywheel to match your clutch and transmission.
ORIGINAL: 97targa
You got that backwards. The 99's had the 6bolt 10.5" flywheels. The late 01-04's had 11" flywheels and were Windsor blocks that had 8 bolt cranks. So, you'll need an 11" 8 bolt flywheel. You can re-use your clutch if you want, but you'll have to get a 10.5" flywheel with 8bolts. I reused my 10.5" clutch with my cobra swap because it was new. I just bought an 8bolt flywheel and good to go. It should be a piece of cake!
ORIGINAL: Mark99GT
ORIGINAL: Mark99GT
lol, no man you got it backwards I have a 99 I just dropped an 03 shortblock in. 99/00 are 8 bolt 10.5"windsors. He'll need a new 6 bolt 10.5" flywheel to work with the T-45. I just went through the same thing.
ORIGINAL: 97targa
ORIGINAL: Mark99GT
hey! i just did a similar sawp in my car. i blew up my motor so i bought a new 04 complete motor. you'll def need a new flywheel. and because of the different pulley set up from your old windsor block to the romeo block you'll need to modify the a/c lines, you'll have to bend them because they will rub, you'll need to modify your power steering reservior bracket to fit on the new block, and you'll need to get a new radiator hose because the old one will be too short.
