anyone swapped ball joints on their stang?
Here next week I will be replacing the ball joints on my 02. I have done ball joints a few times before, but just wondering if there is anything special? ie, the normal ball joint press kit wont work? I know I need put it on stand, release sus to full droop. undo swap bark end links, unbolt lower shock, remove spring, then remove spindle from lower control arm with fork tool. Then press out and pop in new one, but anything special??
RE: anyone swapped ball joints on their stang?
thank ya sir, just what I had in mind, no problems with the rented ball joint press kit? I have used it several times before, just the ball joints look huge compared to other trucks I have worked on
ORIGINAL: 96gtchinook
no need to take your coil spring out, and only unbolt the two bottom bolts on the strut and push it to the side this will save you hassle.
haha, I got that down good, after reading everything like 6 times last year when I did the upper and lower ball joints on the front axle of my old dodge truck
Matt's 95 Stang
10-05-2015 07:16 AM
