Rear leaking?
Rear leaking?
I have a 2002 Gt that just passed 40k miles. its been garage kept all its life except for one summer and never taken to the track or ran rough. my question is yesterday my parents noticed a oil spot in the garage and to check for leaks and to check my oil. checked my oil this morning and it was fine but my dad looked under the car and noticed oil right under my rear. im not driving it today and im going to drive it to a shop 10 miles up the road tommorow morning. i dont know how long its been leaking for and my dad thinks it might just be a gasket needing to be replaced or i could of cracked the cover or gotten too hot then cold and expanded differently. but i was just wondering if anyone has had this happen.
RE: Rear leaking?
If its coming from the rear it could be the cover gasket, which is just an RTV sealant. You may look around your wheel wells for signs of fluid being slung out of the axle seals, or sometimes pinon seals will leak down the diff and collect around the cover area.
RE: Rear leaking?
Where's it leaking from? How bad is the leak?
If it's really minor, it may just be coming from the breather, which is normal.
If it's leaking from the differential cover, it's an easy fix... Tube of gasket material = $3? Oil refill = $40+
If it's leaking from the pinion seal (where the driveshaft connects), again, relatively cheap fix. New pinion seal can't be too expensive ($10? someone check me on that), plus add the expenses above.
Same goes if it's leaking at the wheel ends, a new seal/bearing isn't expensive... plust gasket material and oil.
RE: Rear leaking?
Yea man its most likely your pinion seal leaking and running down to the back cover...........in my opinion i wouldnt worry about it.......unless you plan on upgrading your R&P then you mite as well fix it.
RE: Rear leaking?
The infamous pinion seal, not related to stangs, but everytime i take my k5 four wheeling i end up having to replace a pinion seal, ive tried everything, the last thing i could think of is the idiot who re tubed my extended driveshaft didnt have it balanced properly.
RE: Rear leaking?
Alright that sounds good. thanks everybody so much.I just wanted to be sure and nothing go wrong in the long run. Thanks for all the help. its a slow leak nothing big just a few small circles. my friend has a lift soI will drive it to his home shop tommorow put it on the lift and fix it this week. Ill probably buy the seal or gasket beforeI take anything off. I looked at a few R&P covers one on american muscle for 160butI think ill just replace the seal.
RE: Rear leaking?
ORIGINAL: GhostRider02GT
hell stock period I cant see that nice n shiny diff cover
