Keyless Enrty
RE: Keyless Entry
If you have a PATS key, you should have keyless... it is all run by the same module... I have it in my 96... Get the FOB off ebay (not the ones I am trying for!!) and put a fuse or something metal in the connector... turn the car to RUN (NOT START) and the door lock will cycle (lock then unlock)... push a button on each FOB you have (up to four), then pull the fuse or turn the key to off... all done!!
Good luck!!
Cheers!!
Good luck!!
Cheers!!
Richman
06-05-2005 09:49 PM
sykopafikjuggla
01-20-2005 03:47 PM
