cobra intake
cobra intake
im building a cobra engine and i have a set of 2003 cobra heads but im having a hard time finding an 03 cobra intake manifold. does any one know where i can find one? and what other intake manifolds would work on the heads?
RE: cobra intake
yea its called an m112 s/c... the 01 intake should bolt up... unless your doing a reg cobra motor build then u want the upper and lower factory s/c ... but if it doesnt work out.. let me know ill take those heads off yah
RE: cobra intake
the heads are the same as the 03/04 cobra and machs but the only differnce is in the cams. the cams in the 03/04 cobra are ground to hold boost longer where as the cams in the mach are not.
RE: cobra intake
you just gotta search a little dude. theres a couple on ebay now
upp and lower
http://search.ebay.com/search/search...&category0=
upp and lower
jwog666
12-27-2021 08:09 PM
