oil on spark plug
oil on spark plug
My stang was sputtering/bogging when i gave it gas so I took the advice most of you said and changed the spark plugs.
I can say it is running better but it still bogs but no where near as bad.
Unfortuanlty on the spark plug closest to the fire wall on the passengers side had oil on it so I think that may have something to do with it [:@].
Anyone want to shoot out ideas of what I need to replace?
thanks all
thanks all
RE: oil on spark plug
that is not a good thing. watch and see if it does it again. Do a leakdown test, compression test and see what is going on. Sounds like oil is getting past the rings on that cylinder.
that would account for the bogging
damn only having internet at school sucks right now.
a friend of my dads said something about a valve boot or something like that?
im just going to have to take it easy until i figure out what it is.
Old Wise Tale that works:crank your car and take a dollar bill and hold over your exhaust pipes. If it's the valves it should suck the dollar bill up into the pipe so DON'T LET GO!
As far as the oil goes, I'm going thru this with my number 3 cyclinder and my piston rings are shot and therefore causing oil soak the number 3 plug. As said before this is not a good thing. My 4v is costing my $3500 to replace the rings, bearings and oil pump and that's only if the pistons themselves don't need replaced, then it would cost more. Dropped mine off at my mechanic's this past Tuesday. Good luck to you as I hope you don't have the same problem. Of course I could've just fixed the one ring but I figured while they're in there might as well ring the wole thing. I only have 62k original miles by the way.
ORIGINAL: Dsmfighter
Engine blow by? Have you checked your PCV system at all? Rule out all the potential small things first.Then do a leak down test.
I would say it's not a valve seal as that much oil woldn't be noriceable on the plug. It's either a badly worn valve guide or ring wear. It's sputtering because that cylinder isn't firing due to oil on the plug.
thanks everyone for your responses. im in the works of getting it figured out now, or atleast trying haha.
I really just can't wait for the new year when I can put in a new engine.
i have the same thing on my 96 gt with 64k miles. it is on the drivers side plug closest to the firewall. i noticed it when i changed the plugs. my car doesnt smoke or run bad so im gonna let it go for now. i only put about 4-5 k on it a year since im in school and then its in storage so im not too worried im just gonna save to build it
Omgitsa88Stang
10-05-2015 07:33 AM
stangin1996gt
09-21-2015 11:01 AM
