bassani midlengths are not even the lowest point on a car after they are installed... so if you are worried about that then do them instead of an actual longtube... because some of them can be low low
i would watch it for sure. They would be VERY easy to scrape. Lots of that can lead to leaks...
I do like the midlengths, went right in, but really tight. Ground clearance is not too bad (c springs + blower+ IC weight up front), but gotta watch it
