Fuel Injector Upgrade
Thinking of upgrading from my 19lb stock FI to the 30 lb, will my 4.6 hanle it? I have the K&N FIPK but do I have to go with an upgraded Mass AIR SYSTEM with the FI upgrade install? TC
RE: Fuel Injector Upgrade
Power adders are objects such as a supercharger, turbo, or NOS. When you run these "power adders" then you are pushing a lot more air into each combustion chamber, thus requiring more fuel. If you put a power adder on your car and dont upgrade the injectors then you run the chance of running extremely lean and blowing the engine or not getting the best performance out of the power adder itself.
With your mods, 19lb injectors are more than enough. I would wait till I did a power adder of such before upgrading any of the fuel system.
But for what? I mean.. you have nothing that requires upgraded injectors. Its pratically a waste of money. I guess if you really wanna do it then you can but get a good tune because they are gonna hurt you more than anything.
Guest
Posts: n/a
ORIGINAL: Thunder Chief
The guy who posted on another forum said the 30 lb would deliver 300HP easy, what's the scoop?...TC
Injectors by themselves will not net you any gains whatsoever.
