changed my injectors and running like ****t
Old 11-08-2007, 07:13 PM
g3tsum96gt
g3tsum96gt's Avatar
Default changed my injectors and running like ****t
ok just changed my injectors and put a cold air intake and changed my spark plugs and wires and now my car is running like crap..... checked all plug wires and they are on like the are suppose to be....running like it has a misfire or something i dont konw, i am lost.... its a 96 gt, it has been giving me trouble starting for about a month and had some people say it was the mass air flow change that too.... calabrated for the injectors and everything. please help
g3tsum96gt is offline
Old 11-08-2007, 07:46 PM
Xemeth
Xemeth's Avatar
Default RE: changed my injectors and running like ****t
Did you properly gap the plugs?
Xemeth is offline
Old 11-08-2007, 10:17 PM
g3tsum96gt
g3tsum96gt's Avatar
changed my coil packs and still doing the same thing can anyone help please
Old 11-08-2007, 10:20 PM
02 Ninja
02 Ninja's Avatar
You did so many things, it's hard to really pin point the problem. Make sure you didn't cross up your spark plug wires, +1 on the s plug gaping.
02 Ninja is offline
Dsmfighter
Dsmfighter's Avatar
Are you sure you have all your plug wires on the respective cylinders? Melted plug wire? You didn't bundle the wires together did you?
Dsmfighter is offline
Old 11-08-2007, 10:22 PM
g3tsum96gt
g3tsum96gt's Avatar
put the old plugs back in it..... they were not bad just changed them to make sure everything was good.... still doing the same thing.... any ideas
Old 11-08-2007, 10:44 PM
g3tsum96gt
g3tsum96gt's Avatar
ok checked the wirescoils and plugs by takeing a plug and laying it on the intake and watching the fire, it looks good.... still has a misfire
changed out the mass air to see if that was it, no.....
DO I HAVE TO RESET THE COMPUTER WHEN DOING ANY OF THIS?????????????
Old 11-08-2007, 11:31 PM
racer02GTstang
racer02GTstang's Avatar
yes... when you mod it its best to reset it.... take the positive cable off for 15-20 min
racer02GTstang is offline
Old 11-08-2007, 11:54 PM
AJ06GT
AJ06GT's Avatar
Yeah, you'd want to reset the computer for the injector or the CAI change. I have a feeling that may fix your problem.
AJ06GT is offline
Old 11-08-2007, 11:56 PM
g3tsum96gt
g3tsum96gt's Avatar
i took my pos. cable off for about 30 min. and the check engine light went off..... still running like crap... any more suggestions...please
Quick Reply: changed my injectors and running like ****t
