TKO Vs. T56 Viper spec
RE: TKO Vs. T56 Viper spec
ORIGINAL: lizzyfan
But you are talking AT LEAST another 500 bucks for the TKO, and it's much heavier then the T-56. It does not have double overdrive, 6th gear in the T-56 is .62 and TKO is 5th is.64!
ORIGINAL: livefast1
if i had the money i would go for the viper spec t56. i dont see the tko being any stronger than that trans and it would be nice to have a wild set of rear gears and still get decent mileage with the double overdrive.
TKO/T56 sticky:
https://mustangforums.com/m_2832353/tm.htm
The TKO is stronger, but the 56 does have that nice .50. One thing to note, I would NOT plan on running a stock gear ratio with a .50 overdrive 56. With a 3.27 rear gear thats going to make for some low RPM on the highway, maybe too low, I would definatly recommend something like a 4.10.
ORIGINAL: 2000GT4.6
The "viper spec" which is somewhere around 2600 dollars new has a double, its a .50 final drive wtih a .74 5th gear. All of them have a "double" overdrive though, an overdrive is anything over a 1:1 ratio. The non viper spec just adds a gear (basically) between a 5 speeds 4th and 5th, giving you a better top end above about 115-120 MPH (depending on gearing).
ORIGINAL: lizzyfan
ORIGINAL: livefast1
ORIGINAL: livefast1
pretty much everything i said above, and with the viper specs 2.66 first gear 4.56s would be comparable to people putting 4.10s on a car with a t45.
ORIGINAL: 2000GT4.6
ORIGINAL: lizzyfan
ORIGINAL: livefast1
My T45 crapped out so I decided to put the T56 in, I LOVE it! T56 w/ 4.10's FTW!
If you get the T56, you need a new clutch, flywheel, shorter driveshaft, different yoke, shifter, and a brace.
ORIGINAL: livefast1
i was saying he pretty much repeated me, and with the vipers 1st gear being a 2.66, 4.56 rear gears would be comparable to the performance/output of 4.10 gears on a car with a t45.
Yea i get what you guys are saying i was lookin into 4:10s but i was also looking to get a kenne bell sometime in the future but i hear they dont do well with 4:10s
