Parking brake lights
RE: Parking brake lights
Probably a loose wire, pull out the diagrams and follow them down, i had an issue like that just it was my reverse lights were coming on.. when i had my clutch put in, the connection to the tranny wasnt solid, ... all i had to do was plug it all the way in insta-fix
ORIGINAL: ohthreeGT
check your brake fluid
If they go off on real hard acceleration only, I'd check your brake switch. It's under the dash by the pedel. There's a pintel sticking out of it. Make sure it's touching the pedel at rest position. The brake switch works opposite from most switches. The lights are off when the pintel is pressed in (when the pedel is at rest) and when you push the pedel down the connection breaks and your brake lights go on. If they're going off under heavy load it may just need to be adjusted. Push the pedel down and take a screwdriver and slightly pull out the pintel... Other than that you're going to have to do some electrical diagnosing.
the light on the dash that comes on when you have the parking brake on also will come on if your low on fluid, itll turn off when you hit the gas or brakes or take a corner enough to make it slosh around
ORIGINAL: ohthreeGT
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
09-08-2015 11:50 AM
