Fuel Pump/injector question
Old 11-15-2007, 07:37 AM
lewistk
lewistk's Avatar
Default Fuel Pump/injector question
Anyone know what the 96GT stockfuel pump is? 110 lph?
also are stockinjectors 19 lbs/hr?
lewistk is offline
Old 12-27-2007, 11:22 PM
lewistk
lewistk's Avatar
Default RE: Fuel Pump/injector question
bump... is there any downsides to getting a fuel pump that pumps a lot more lph than i need right now? i need to replace mine, and dont wanna buy a stock replacement incase of future mods..
lewistk is offline
Old 12-28-2007, 12:01 AM
Quicktime_GT
Quicktime_GT's Avatar
stock yellows up to 01.5 are 19.. the pink in the romeo engines from 01 on are 21lb not sure on the fuel pump
Quicktime_GT is offline
Old 12-28-2007, 04:13 PM
lewistk
lewistk's Avatar
ok. is there any downsides to getting a fuel pump that pumps a lot more lph than i need right now? i need to replace mine, and dont wanna buy just a stock replacement incase of future mods... that i mite need a more powerful one anyway
lewistk is offline
Old 12-28-2007, 05:24 PM
tylerl90
tylerl90's Avatar
I don't believe having a higher flowing pump would hurt you, it probably would help you as a matter of fact.Maybe someone else can chime in with a different view cause I don't know ALOT about fuel systems.
tylerl90 is offline
Old 12-28-2007, 06:59 PM
Sxynerd
Sxynerd's Avatar
If your n/a it wont help or hurt. Although it will help after you start a real build. High compression or F/I build. I just get a walbro 255 or similar.
Sxynerd is offline
Old 12-30-2007, 03:13 PM
fausty
fausty's Avatar
im going to use the svt focus fuel pump which pumps 255lph will my car be fine runing that until i start my future build
fausty is offline
Old 12-30-2007, 04:24 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: fausty
You'll be fine
lizzyfan is offline
Old 12-30-2007, 07:52 PM
JayDs Ibanez
JayDs Ibanez's Avatar
i think you'll be fine with the fuel pump also, the injectors are 19 for older engines and 21 for newer like 02's and later i think
JayDs Ibanez is offline
Old 01-07-2008, 11:35 PM
simplyme0484
simplyme0484's Avatar
Will a 98 GT N/A at 310rwhp gain any more power with24lb injectors and a 255lph fuel pump?
simplyme0484 is offline
Quick Reply: Fuel Pump/injector question
