Direct Port Nitrous....
I'm thinking about using nitrous on my car since it will still allow me to autocross it ocasionally ( since stockish GT power is plenty for that, hell look at Miatas' ) and get retain factory like drivability when I;m off the bottle. I know that the 4.6 intake manifold has some problems playing nice with wet shots since the fuel likes to puddle in the bottom and go boom[:'(], so I'm looking at a direct port setup. I'm kinda torn between two kits though, an NOS and a NX. The NOS kit is the NOSzle setup ( uses spacers under the injectors to inject fuel and nitrous ), with a 10 lb. bottle a RPM window switch and a Fuel Pressure switch for just over $1400. Link to said kit: http://store.summitracing.com/partde...p;autoview=sku
The NX kit is basically a fogger setup with 8 "Piranah" nozzles that would require drilling and tapping the intake manifold as close to the injector bungs as possible to prevent puddling. This kit runs just shy of $900 and I'd add a purge kit, window switch and a fuel pressure saftey switch so I'd figure around $1250 for everything I'd need to be safe. Link to said kit:
http://www.americanmuscle.com/nx-v8-efi-dps-8605.html
Now with either of these kits I'm going to stick with a MAX of a 125 shot right now until I can build up my fuel system then bump up to a 200 or so. The NOS kit is pretty much made for the 4.6 ( albeit more expensive) while the NX kit is basically a universal kit and a bit cheaper. And both companies seem to have good quality products. So my question for you guys is which kit is the best to go with?
RE: Direct Port Nitrous....
you will be fine with a regular nozzle setup taped into your intake. why would u wast your money on that for such a little shot? ive had my nitrous for about 3 months now and no problems and ive been though 3 bottles. just get it tuned and use quality nozzles and put it about 6-8 inches away from the tb so the fuel can mist even more. with all that im sure you will be pretty safe. this is coming from a person with a zex 125 wet shot.
It is just going to be set at a 125 shot for the time being, after I build up my fuel system I'm going to run a 200 shot or maybe higher when I take it to the track. I'm not planning on going FI later down the road so I figure why not go with one of the best nitrous setups I can find. Plus two guys I know around where I live have shattered their intakes on their 4.6 from a backfire. One was running a 175 wet shot tuned by MPH, and the other was running a 125 wet shot tunned by a local shop. Nothing was wrong with the tunes, maybe some sort of system failure or a solenoid sticking or something, but it only took one time and boom, bye bye intake. I just want the safest nitrous system I can get, plus if I decide to go even bigger later down the road all I have to do is buy bigger jets, not a whole new system.
i have full exhaust, tb/plenem and tune.
if you get all the safety features, window switch, fpss, wot switch, fuel pump just for safety, good tune you will be fine. i still need to get a fpss.
Don't be fooled into thinking a Direct Port system is any safer than a single nozzle or plate system. Like any power-adder, nitrous systems can fail with bad results. Please check the pic below[8D]
I run a nitrous express plate system 100 shot on my 01gt with no problems. m y buddy was spraying his 00 with 150 shot with upgraded fuel system window switch low pressure switch all the safe guards and still had detonation problems. busted a piston.
jwog666
12-27-2021 08:09 PM
