tranny leak
RE: tranny leak
That seal seals on the yoke. Pull the drive shaft back out and check for a groove in the yoke where the seal rides on it. I've seen several times where the seal can literally cut a groove in the yoke making it impossible for any seal to completely seal. Just something to check. If the yoke is ok then your drive shaft might be out of balance causing a slight vibration to wear the seal out.
bradleyb
11-27-2015 07:50 PM
treesloth
09-28-2015 07:03 AM
