I think its a iac prop??Help
This doesnot happen all the time only happended twice so far.... after driving on the freeway for say about 18miles at no more than75mph when i get on the on ramp and put her in nuetral and press on the brakes to slow down the car will go down to about 100-200 rpms and almost stall and will jump up to the normal 6k and then back down to 1-2 k(this will happen twice or so) then will go to normal... the first time this happened the car just stalled.... i started noticing it after i did my manifold swap to the one with a aluminum cross over. checked for leaks cant find nor here any and other than that the car drive fine.
Thanks
Thanks
RE: I think its a iac prop??Help
same thing just happened to my 96gt. i swapped out the iac valve and checked for vacuum leaks and it stayed the same.... ive heard my problemcould be abad fuel pump which i intend to do this week, so this could be your problem too?
looking at ur pics looks like u have a s/c , i had the same problems with mine, i had to turn my idle up to about 1100 to avoid stalling issues, not really sure whats up either.
