Cant get crank pulley off HELP!!
11-18-2007, 07:25 PM
Im in the middle of my PI swap right now, and what can I used to hold the pulley inplace while I loosen the bolt!!!
11-18-2007, 07:49 PM
RE: Cant get crank pulley off HELP!!
Come on guys, this is holding me up!
11-18-2007, 08:44 PM
Put it in gear, have somebody stand on the brake and use a big breaker bar.
11-18-2007, 09:02 PM
I tryed putting it in gear, and having someone on the brakes, it didnt work. I ended up borrowing a buddys impact gun and it worked out fine.
11-18-2007, 10:07 PM
your car does have to be a stick shift with a good clutch for that to work.
11-18-2007, 10:15 PM
Yea my car is a 5spd, and it got a King Cobra Clutch in it, but it didnt work either way...when all else fails, use air tools
11-19-2007, 12:41 AM
You should go buy a harmonic damper pulley removal tool. Makes your life SOOOO much easier.
11-19-2007, 02:09 AM
he is talking about removing the crank bolt... not the balancer itself. heh
11-19-2007, 06:18 AM
wow, did the car move, or the clutch slip when you tried the second gear thing?
11-19-2007, 06:29 AM
Impacts FTW
GimpyHSHS
19
12-19-2023 01:12 PM
spdeplayer2
10-24-2015 09:45 AM
svfetter
10-05-2015 11:39 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
Wombatnation
09-13-2015 09:16 PM
2006,
2007,
46,
cranck,
crank,
crankshaft,
ford,
gt,
mustang,
pulley,
remove
