metal flakes in discharge tube? (with Pics)
Old 11-20-2007, 02:40 PM
sunguf
sunguf's Avatar
Default metal flakes in discharge tube? (with Pics)
I was piecing every thing together from the Vortech V2 kit I bought from tedd at TMS and I happen to notice some metal flakes in the inter walls of the discharge tube (Intake piping) Is this something I need to worry about? they seems to really be stuck onto the walls but can be picked of. is the headunit going bad? did the other persons motor blow causing this? Now I'm worried about using this kit that i spent money on
Pictures:
sunguf is offline
Old 11-20-2007, 03:20 PM
98SN95
98SN95's Avatar
Default RE: metal flakes in discharge tube? (with Pics)
I would not use that man, you said you bought it new rite? if new then return for different one, if used with time on the headunit already, you need to ask some questions???
98SN95 is offline
Old 11-20-2007, 03:23 PM
98SN95
98SN95's Avatar
also sometimes from the forging process the pipes will come out this way, even if they are brand new. Looks like poor quality tubing!
98SN95 is offline
Old 11-20-2007, 03:31 PM
sunguf
sunguf's Avatar
this is a used kit that has about 15k miles on it. should i be worried about the headunit? it seems to spin freely and no play but if that's coming from the headunit I would hate to install it and blow my motor from metal going in.
sunguf is offline
Old 11-20-2007, 03:56 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Is there any indication that the impeller has been shedding metal, and/or where those flakes might have come from? I wouldn't run that puppy on my engine 'til I had some idea where the flakes came from...
cliffyk is offline
Old 11-20-2007, 04:07 PM
sunguf
sunguf's Avatar
this is what he told me
"pipe was in a box with misc. parts
i believe that that is just particles stuck to the pipe from it sitting around
this has nothing to do with the motor blowing up due to the supercharger.
I would get that pipe cleaned out before use"
sunguf is offline
Old 11-20-2007, 04:17 PM
contentsunderpressur
contentsunderpressur's Avatar
If those particles came from the head unit then it would have to be from the impeller scraping metal from the case. If it is doing that then the bearings are gone in the charger and you will be able to move the impeller up and down and side to side or in and out. You should be able to see if the impeller has made contact with the housing just by looking at the impeller as well. Those pipes do look like that sometimes.
contentsunderpressur is offline
Old 11-20-2007, 04:25 PM
sunguf
sunguf's Avatar
It has no play on the headunit. so I shouldn't worry and just clean up the pipe?
sunguf is offline
Old 11-20-2007, 04:34 PM
It's your call. That's what I would do. The metal couldn't have come from the head unit if there is nothing wrong with it. If it was a bad bearing then the seal would be bad were the metal shavings came through and there would be oil down there as well. If it was from the impeller shaving off the housing you would see that too.
Old 11-20-2007, 04:47 PM
sunguf
sunguf's Avatar
is there any way of checking the headunit without sending it to vortech?
sunguf is offline
Quick Reply: metal flakes in discharge tube? (with Pics)
