Stock gears to 3.73 or 4.10
Old 11-24-2007, 08:20 PM
MJH78
MJH78's Avatar
Default Stock gears to 3.73 or 4.10
thinking about changing gears. What are most people paying (labor) to have these changed out? The only cons I've heard of on this are a little less fuel mileage and having to recalibrate the speedo somehow. How hard is it to calibrate the speedo with the proper piece of equipment...I think someone sells it for about $90? My car is stock, 75K miles in exc. condition, I drive 3K miles per year basically in town driving.I don't race, Idon't give a damn about my top speed, I just figured changing gears would give it a little more in the fun-to-drive area. 3.73 or 4.10? What should I know? will i notice a substantial difference in how the car drives? gracias
MJH78 is offline
Old 11-24-2007, 08:31 PM
cammed99gt
cammed99gt's Avatar
Default RE: Stock gears to 3.73 or 4.10
The 4.10s is def. more fun then the 3.73 because i had both.If u want in town fun go with 4.10s.
cammed99gt is offline
Old 11-24-2007, 09:39 PM
scfd524
scfd524's Avatar
Just get a new speedo gear for like 20 bucks. I believe its a 23 tooth.
scfd524 is offline
Old 11-24-2007, 09:53 PM
mvr
mvr's Avatar
sounds like your car is a weekend car. id go with 4.10's.
mvr is offline
Old 11-24-2007, 10:16 PM
dave22478
dave22478's Avatar
If you have a 99-04 its not a gear, you need a tuner to recalibrate the speedo.
dave22478 is offline
Old 11-25-2007, 01:23 AM
Sxynerd
Sxynerd's Avatar
I'm going to 4:10's... I don't know if it's the rgith gear or not but whatever. If I hate it I'll only be driving it on emore summer before I sell it anyway!
Sxynerd is offline
Old 11-25-2007, 06:37 AM
momob009
momob009's Avatar
i have a 02 gt automatic i want to go with 3.73 gears and a lighter drive shaft would i notice a difference form the 3.27 i like to travle the interstates and im not racing on a stripe just want a litttle more get-up and go
momob009 is offline
Old 11-25-2007, 06:38 AM
99GTvert
is my username.
99GTvert's Avatar
I have 4.10s. Love them.
If your car's year is a 1999 or above, then you need a tuner or speedo adjuster to adjust the speedometer. 98 and below just requires a little gear.
99GTvert is offline
Old 11-25-2007, 01:35 PM
GT03 TJS
GT03 TJS's Avatar
a weekend warrior thats pretty much used for fun in-town? i'm suprised nobody here said 4:30's or 4:56's.....
GT03 TJS is offline
Old 11-25-2007, 01:51 PM
Shelbyville
Shelbyville's Avatar
I am sure someone will disagree, but I would go with 3.73. I was going to and changed my mind and went with 4.10's. The problem with 4.10's is you run out of first gear so fast. Maybe 3.73's would be the same. I can't say. You will definitely feel better pickup regardless of which gear you get. Also, if you are ever up on the highway in 5th, you will feel the difference if you hit the gas. Most shops will charge you 4-5 hour labor to do this. I know it doesn't take that long to swap them out, but thats what they will tell you. As far as a tuner, I believe you can buy one just for speedo calibrations which is a lot cheaper than getting a full function tuner which can run around 350-400.00. Whoever you get, make sure they are good. Gears not put in the right way will cause you grief down the road. Good luck.
Shelbyville is offline
Quick Reply: Stock gears to 3.73 or 4.10
