a leaking valve cover gasket is the only way that i could get oil in my plug holes right? what are the chances of both valve covers leaking....i have oil in plug holes for 4 and 8....ford dealership says that is the only thing that could cause it, but i wanted to see what you guys think...
ok thanks, thats what i thought, just found it strange that the valve covers would suddenly BOTH leak after an intake swap...coincidences at their finest lol
Check and make sure your pcv is working. You might have to much crank case presure and its pushing out there. I doubt it but its possible. I had it push oil out of my front crank seal until i fixed my pcv system.
Just fixed this on my friends 98 Cobra. It was the valve cover seal. Not to hard to fix. Just need a jack to slightly raise the engine to get the valve covers off...you just need a day.
