Please Help Me!!!!
Please Help Me!!!!
ok, first the basics: 2000 mustang gt, 5 speed with a short throw, 3.73 gears, nitto drags, maximum motorsports lowering kit with bilstiens.
PROBLEM: when my 4.6 is cold, everything is fine and dandy. but when it gets warmed up there is a ticking noise coming from the back of the engine on the passenger side when ideling. but heres whats weird to me. it ticks 3 times then stops for a couple of seconds, then 3 more ticks, then stops and so on. Also, when i am crusing along at about 3000 rpm i get a much louder ticking noise when i gently push the gas down or hold the gas steady. when i hit the gas hard though, it goes away and there is no noise when i slow down. i have had a couple people tell me what they think is wrong, someone said that shes spittin plugs, one said sticky lifter, and one said rod knock. so i really have no idea. any help or opinions would be very much appriciated.
Mike
Mike
RE: Please Help Me!!!!
Well for one you dont have lifters in your engine, if its the plug better check them all right now before you drive the car again and a rod knock would be constant and speed up with the rpm. My bet would be on a plug or exhaust leak.
to me it sounds like a valve problem. you say the sound isnt consistent. remember that the cam timing turns at half crankshaft speed so if the sound is very inconsistent its possible you may have a valvetrain problem.
