need help with heater fan
RE: need help with heater fan
ORIGINAL: 99_GT
Sounds like your flapper valve thatdiverts air to the vents and the floor isstuck or broken.
I think that it is controlled by vacume air pressure. You can remove the control panel on the dash and the vacume lines are on the back of the selector switch. Maybe you lost the vacume feed to this control ****. If it is the flapper door then it will be a tough repair.
Yes, look under the hood where the ac lines go into the firewall. There is one little black vacume line that goes into the firewall there that provides the vacume for the ac controls. It's bad about getting brittle and breaking.
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
