New found $$
RE: New found $$
ORIGINAL: jdaniel
Well you have the motor finished. I would invest in a tubular K member, tubular A arms, 10 way adjustable struts (take off the stock sway bar) and you should be able to yank the whole front of the car up and put all that weight on the rear tires. You would be looking at some low 60' times.
Thats what I would do.
RE: New found $$
I have been looking at the Reichard Racing intake.
6061 T6 Billet Aluminum Flanges
20% Larger Port Design Than Stock
Stock EGR, IEC & Throttle Body Locations
Will Accept Aftermarket Fuel Rails
Can be Used with NOS Dry Nitrous Systems with no modifications
Reichard Racing Intake Gains up to 55+ HP over the Ford Bullitt intake
See Dyno results.
See performance test article from modularfords.com
Available in 3 Styles
Oval Throttle Body to Accept Twin and Oval Butterflies
Round Throttle Body
Carburetor Application
See Dyno results.
Round Throttle Body
RE: New found $$
ORIGINAL: code3GT
Got 4.10's, no spray, YET, Steeda Tri-Ax, Eibachs. Already have your suggestions.
ORIGINAL: kubball2005
How about some 4.10s, spray, MGW shifter, maybe some springs?? There's an endless selection
RE: New found $$
ORIGINAL: Mike02GT
Gave you taken it to the dyno??? justa wondering what the results are from your mods...
RE: New found $$
ORIGINAL: code3GT
See Dyno results.
Round Throttle Body
See Dyno results.
Round Throttle Body
