2003 GT misfire???
2003 GT misfire???
Hey guys,
I am having a problem with my 03 GT. One day it started running like crap and it had a bad mis-fire. It tripped the check engine light soI went into the part store and plugged it in and it said "cylinder 6 misfire" SoI bought new plugs and I replaced just cylinder 6 first to see if that would help and it didn't, so then I took the coil pack from cylinder 5 and swapped it with cylinder 6 then went to the part store and erased the codes. Then I was going to see if the service engine soon light would kick on again and if it said "Cylinder 5 misfire I would know what the problem is. The car runs a lot better than it did but it still has a huge misfire, especially when I am starting out in 1st gear or whenI floor it in 4th gear doing about 40 MPH. The light has not kicked on it weeks!! And the thought of my car not running right kills me. When it says cylinder 6 misfire, could that mean it could be an injector as well? What should I do from this point guys???? Thanks in advance!!
Omgitsa88Stang
10-05-2015 07:33 AM
junior04
09-28-2015 10:53 AM
