crank pully 2 pieces?????
Old 11-28-2007, 11:03 PM
Mark99GT
Mark99GT's Avatar
Default RE: crank pully 2 pieces?????
I put it in gear and left the parking brake on. Worked fine for me. You've got to stop it somehow or it will just turn the engine over.
Mark99GT is offline
Old 11-28-2007, 11:34 PM
racer02GTstang
racer02GTstang's Avatar
you can also use an impact....
racer02GTstang is offline
Old 11-29-2007, 06:56 AM
BraMas
BraMas's Avatar
Definitely use an Impact if you have access to one. It will zip that center bolt right out
BraMas is offline
Old 11-29-2007, 08:09 AM
98SN95
98SN95's Avatar
If you have air tools, this would be ideal for this type of job, if not, just like what was said above, leave it in gear with the e-brake on. A HAYNES manual should show you the tools you need!
98SN95 is offline
Old 11-29-2007, 09:05 AM
Cornbread01
Cornbread01's Avatar
no impact but in gear with the e brake on will work just as good. thanks for your help guys... will post a pic of the old pos and the new sfi when its here hopefully saterday....
Cornbread01 is offline
Old 11-29-2007, 10:54 AM
GolfmanSpeck
GolfmanSpeck's Avatar
ORIGINAL: Cornbread01
You know that that one is an underdrive pulley, right? Without the one for water pump and alternator, you might run hot at idle and get light dimming too.
GolfmanSpeck is offline
Old 11-29-2007, 12:35 PM
Cornbread01
no its not underdrive.... there are sfi aproved that are the same size as stock and that is what i purchased...made sure of that
baddog671
07-26-2016 01:20 PM
svfetter
10-05-2015 11:39 AM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: crank pully 2 pieces?????
