head gasket
Old 12-01-2007, 06:52 PM
Mark99GT
Mark99GT's Avatar
Default RE: head gasket
Well you'd have to read up so you know what it entails. But all said and done, its really not that bad. You could definitely do it over a weekend. You should not have to machine your heads unless they're already warped or you drop them or something and mess them up.
Mark99GT is offline
Old 12-01-2007, 06:53 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
it looks like about 120-150 for a head gasket and the bolts, anything else i would need?
99BlackPonyGT is offline
Old 12-01-2007, 06:55 PM
99BlackPonyGT
is there a writeup anywhere on here?
Old 12-01-2007, 07:19 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
It's not needed, but if you're taking the heads off, I'd do a bunch of other things while I'm there, especially depending on mileage... Timing cover gaskets, valve cover gaskets, intake manifold gaskets, oil pump, timing chain tensioners, head bolts, valves, springs... The list is goes on and on... To do head gaskets you have to take the engine down to it's shortblock. The timing cover (along with all acessories) has to come off. I'd take a loan out from the parents or something. If you're doing all of this work you might as well do it right and all at once. Just like said above it's a lot of work; not hard, but just a lot of it.
96GT226410 is offline
Old 12-01-2007, 07:23 PM
99BlackPonyGT
thats great and stuff if i had money...i dont have the luxury to drop 2 grand in my car at the moment...its in with our family mechanic as we speak getting timing chain tensioners put on, i can barely afford that.... i just need to take the quickest cheapest way to fix it, im not doing heads cams chains gaskets pullies and everythign else that needs to be removed from the engine to do this, i just need the problem fixed....thanks for the help guys, but i guess im just gonna try to find a mechanic that isnt going to rape me
Old 12-01-2007, 07:26 PM
99BlackPonyGT
and i cant take a loan out....i am payin for my car, it wasnt a gift....i cant afford to borrow more money...if it gets too bad the car is going to end up stolen and set on fire in some field, use insurance check to pay off the loan and then just buy a ****ty civic until im outta school
Old 12-01-2007, 08:48 PM
oxfordgt
oxfordgt's Avatar
ORIGINAL: 99BlackPonyGT
Holy crap just go up there and ask if you can change the head gasket real fast. If he is changing the timing chain tentioners there are only 2 fast steps to change the gasket. 1. disconnect the manifold from the midpipe. 2. pull the head bolts. **** if I was the mechanic and you brought the gasket and bolts I would probably tack on an additional $80 to change the head gasket for you. Talk to him and see how far he is on the tentioners.
oxfordgt is offline
Old 12-01-2007, 09:06 PM
Mark99GT
Mark99GT's Avatar
ORIGINAL: oxfordgt
+1 NO ****!!! GET OVER THERE NOW-SERIOUSLY-GO NOW!!! You're paying that guy to do at least 75% of the work you'd have to do anyways. You still gotta remove the intake manifold but thats no biggie...
Mark99GT is offline
Old 12-01-2007, 09:35 PM
97mustanggton18s
97mustanggton18s's Avatar
^ true story
97mustanggton18s is offline
Old 12-01-2007, 09:42 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
+2! If your mechanic is going to charge you $1,200 more to do head gaskets while he's doing timing chain tensioners he's screwing you blind. Some people give us technicians a crappy rep.
Quick Reply: head gasket
