will check engine light go off?
i have previously posted about a posibly bad camshaft posistion sensor, i have found out how to test it and i wanted to know if i started the engine with the sensor disconnected if a check engine light will come on and if it will turn off when i reconnect the sensor.
Thanks
Thanks
RE: will check engine light go off?
It shouldn't come on if you just crank it and then hook it back up... Yes it will go off when you re-connect it, might take it a little while but it will go off when it realizes that the sensor is back on. If not, just disconnect your battery for about 30 minutes and it will reset.
