Buy a catback or have a shop make me one?
#21
RE: Buy a catback or have a shop make me one?
ORIGINAL: Cassies01GT
What do you mean not the bomb? They are the same as a flow, and if youve ever seen an IMCO aka cherry bomb they are built better IMO
I'd go for the Magna-(whichevers) for $319 before I'd go with weld ins though. I've got a video of my cheapo exhaust on my myspace. Its a Spintech catback, which is rare, but you can find the Spintech violator mufflers fairly easily.
#22
ORIGINAL: bluepony4.6
Unless you have a turbo or other method of forced induction, I would not get 3" piping. Our cars need backpressure. I wouldn't go over 2.5" with mandrel bent piping. Unless your shop has the ability to mandrel bend the tubing, I would get one on the aftermarket. But that's just me.
By the way 3" piping on a low hp vehicle sill cause backpressure.
#24
Cherry bomb's sound like a$$ imo. The reason imco mufflers are so much cheaper is because the quality of the piping. If you had a close friend that works or owns a quality exhaust shop, they'll tell you they're cheap and prone to rusting! Companies like magnaflow and any other quality brand have guarantees on defects, you wont find that with cheaper "off brands".
#25
ORIGINAL: oxfordgt
Explain this to meThis should be good.
#26
ORIGINAL: arcticman37
You beat me to it......3" or low back pressure would be fine esp. with a tune guys!!
ORIGINAL: oxfordgt
3" exhaust is overkill on a stock 2 valve. I see it all the time on ricers. They put a big exhaust on their car and then have to rev the **** out of it to get off the line. We don't have torque monsters straight from thefactory.
Some people don't prefer to keep their vehicles in the 3000 - 5000 rpm range all the time.
#27
Ok thats an ok reason. But if you are going for power then you want the least amount of backpressure in your system as possible. You want your powerband to be moved up. You have to build the car in the right steps if you want a good performer. Once you have a good flowing exhaust you need gears to get you in your power band faster. But if its a daily driver and you want that low end torque then save your money and stop modding your car.
#28
ORIGINAL: oxfordgt
