yeah you would still get atleast 11HP with stock exhaust.....but on the 70mm to 75mm, there seems to be confusion....if i was you, i would buy the 75mm.
If you had to get 1 out of the 2. Either the 75mm TB or the aftermarket plenum which would you buy first?
Neither are going to make much of a difference without the other to compliment it (even then you're looking at like maybe 5rwhp). Ideally you should just save up and get them as a package deal. If you can't afford them both skip it all together (a short throwshifter would be a better investment).
And don't buy into the accufab hype. Sure they make great products, but when it comes to tb/plenum combos they're all about the same. The 200 dollar ones work just as well as the 400 dollar ones.
When I had my 75mm accufab tb/plenum combo (snagged it on ebay cheap) all I really noticed was better throttle response and maybe a tad more pull on top. But that alsocouldjust be the psych factor...
I bought a Mac 70mm tb for $40 used. Buy whichever one you can find the cheapest unless you're sure you're going F/I down the road. In that case get the 75mm.
