lt header install
#22
RE: lt header install
ORIGINAL: MU71L4710N
still gotta drop thek member for shorties man
ORIGINAL: MustangChris04
shorties require half the amount of effort and time to install as apposed to long tubes.
#25
ORIGINAL: stangdriver2007
can the longtubes be installed when the heads are off and not have to take out the k member
#26
ORIGINAL: bluepony4.6
Good question. I've been wondering the same thing. It seems to be a viable option but I don't have a clue.
#27
ORIGINAL: blkthndr03
so how many hours of work am i looking at to install lts i have access to a lift would that make it easier
#28
ORIGINAL: AllGo5.0
I have beem wondering that also. I doing a PI swap as soon as i decide what all i wanna do, so i can dothem at the same time. So if i can get LTs in there with the heads off the would be awesome.
#29
I've never put headers on but when I took my transmission out I could tell that it would bea pain.. I actually had to drop my K member just to get my transmission back in around the LT's that were alreadyon my car...
If you do try to do it.. just drop your k member from the beginning.. I thought I could take my transmission out without dropping the K member... I got it out, only by taking the clutch bolts off and letting the clutch fall into the bell housing to clear the input shaft.. There's no way it would have went back in like this though...
Its a pain.. made me hate LT's
#30
it is possible to get a trans in around longtubes, i did it in may. Put the trans on the jack laying on its left side, raise it up and muscle it around the right side header. it's a two person job. The headers also have to be loose. The hardest part is getting the headers to squeeze past the part of the bellhouseing where the starter bolts up to. And you can deffinatly install headers LT or shorties without dropping the K-member. The proper procedure is to lift the motor up a few inches with the mounts unbolted.
