4.6l compression ratio
RE: 4.6l compression ratio
The compression ratio would be 9.8:1 with NON-PI heads and 10.7:1 with PI heads. With Non-PI heads you will be fine on pump gas but with PI you will have to run 93 octane and pull timing out.
ORIGINAL: stangiac03
thanks. are you sure on this cause i have asked numerous people and i have gotten so many diffrent answers one guy told me 11.3:1 on NPI heads. lol.
ORIGINAL: contentsunderpressur
Yes, oxford knows his ****.
11.3:1 sounds high and from what I have been told you will have to run race fuel.
So what numbers are you using to calculate the CR then?
Ive got:
Bore: 3.552"
Stroke: 3.543"
Piston Dish: 4.54cc (I read somewhere else they were 3cc)
Head G Bore: 3.625"
HG comp thickness: .03"
Deck height: .012"
CC volume: 51cc (I also read these were 49.77cc)
I'm getting a CR of 10.2:1 with the NPI heads and 11.5:1 with the PI heads. What numbers do you use?
Ive got:
Bore: 3.552"
Stroke: 3.543"
Head G Bore: 3.625"
Deck height: .012"
