Gear Bearings...
Gear Bearings...
Ok I'm putting in some 4.10s pretty soon and wanted to replace the bearings as well because I've got 90k miles. I bought THESE bearings on ebay and my uncle said they were the "outer" bearing and seals and I still need "inner" ones. Is this true? He knows a hell of a lot about cars but I'm just double checking what he's telling me. I'm getting really anxious to put these 4.10s on so any feedback would be great. Thanks.
Matt
Matt
RE: Gear Bearings...
ORIGINAL: 96SilverLT1
Those are axle bearings.. you need diff bearings. They should come with the install kit
No I have everything I need with this Motive kit. It has a shim assortment, races, crush ring, blah blah blah, all I need are the bearings, and I guess I need the inner bearings because that ebay auction was for the outer ones, I just didn't know it.
ORIGINAL: hotrodmanII
those or outers, you dont really not the ones that go on your posi unit unless they bad ,,drive down and i will install the for free ...cause im cool.
there are no inner bearings for the axles, they fit into the differential which is supported by the differential bearings which you should already have in the rebuild kit. there are a total of 6 bearings in the rear end, two on the pinion, two on the differential, and one on each axle at the outer end. I guess your uncle was referring to the differential bearings when he said you needed the inner bearings.
